Dull chrome roller function
Discussion in 'Heidelberg Printing Presses' started by Raman karthi, Nov 29, 2020.
  1. Raman karthi
    Raman karthi Senior Member
    Aug 2020
    103
    nigeria
    Dear valuable members,
    Please can I know what is the usage of dull chrome roller in dampening unit and how can I control the dampening feeding up and down with the adjustment of this roller connecting with dampening from roller?
  2. Beguin
    Beguin Senior Member
    Jan 2020
    348
    Côté d'ivoire
    Picture please
  3. Raman karthi
    Aug 2020
    103
    nigeria
    Dear sir,
    I am asking about the roller oscillating down side from dampening form roller
  4. Beguin
    Jan 2020
    348
    Côté d'ivoire
    It's just to see the kind of wetting you had to tell me about it. Thank you
  5. asem alsafady
    asem alsafady Senior Member
    Mar 2016
    180
    Amman Jordan
    Dear Raman,
    I guess you are asking about the dampening distributor roller, if yes.
    You have to adjust the dampening form roller against this roller.
    In SM102 their is a screw directly at the roller journal.
    In SM74, SM52 the screw is under the water pan.
  6. turbotom1052
    turbotom1052 Senior Member
    1,054
    Vermont
    If im remembering correctly this roller is a fixed roller. That is to say that its NOT adjustable. What is adjustable is the rollers that contact this roller.
  7. Beguin
    Jan 2020
    348
    Côté d'ivoire
    Hi what roller are you talking about because there is the doser that comes on the bubbler and the moistener and the depressor that makes contact with the moistener.
  8. Raman karthi
    Aug 2020
    103
    nigeria
    Thanks for the your response; I was asking about the distributor roller to dampening form roller.
  9. Beguin
    Jan 2020
    348
    Côté d'ivoire
  10. Raman karthi
    Aug 2020
    103
    nigeria
    Dear sir,
    I want to know CD 74 dampening roller setting, because if I adjust the rollers each other, adjustment the screws clockwise or anti clock wise for increasing pressure?
  11. Beguin
    Jan 2020
    348
    Côté d'ivoire
    please can we have the picture of what you want done.Thank you
  12. asem alsafady
    Mar 2016
    180
    Amman Jordan
    Dear Raman
    Turning the screw clockwise increases the pressure between rollers, and vice versa.
    And as Mr.Beguin mentioned it would be better to send a photo of what you need to adjust.
  13. Raman karthi
    Aug 2020
    103
    nigeria
    Thanks for the information.
