Upping the amount of fuser fluid onto fuser roll
Discussion in 'Xerox iGen3, iGen4, & iGen5 Digital Presses' started by gavywill, Oct 21, 2020.
  1. gavywill
    gavywill Senior Member
    Jun 2012
    101
    UK
    Hello All,
    Is there a way to up the amount of fuser fluid onto paper?
    Like an NVM adjustment. Just curious.
    Many Thanks
  2. Milo Wilson
    Milo Wilson Senior Member
    Dec 2007
    477
    Arkansas
    That line on your fuser roll is not due to not enough fuser oil. That's an issue of your RDS for the fuser assembly being turned off
  3. gavywill
    Jun 2012
    101
    UK
    Hi Milo,
    How do we turn this back on?
    Thanks in advance.
  4. Milo Wilson
    Dec 2007
    477
    Arkansas
    Have to go into diagnostics on psip. You can give me a call at 714-292-6912 andI can walk you through it.
  5. gavywill
    Jun 2012
    101
    UK
    Hi Milo,
    I'm not currently at work finished at 10pm. Is it located as a NVM ID then you have to tick the default value box in order to get it back on?
    Many Thanks
    Gavin
  6. Milo Wilson
    Dec 2007
    477
    Arkansas
    Exactly. It will be located in P1 nvm in fuser switches.
  7. gavywill
    Jun 2012
    101
    UK
    Hey Milo,
    One last question, If I'm printing on 90gsm Arrow Silk with very high tints(That Dry out the fuser roll quickly) , Would it benefit the iGen to increase the amount of fuser fluid on to the paper?
    Thanks in advance for your advice.
    Gavin
  8. Milo Wilson
    Dec 2007
    477
    Arkansas
    Are you getting constant off setting or is your fuser roll getting contaminated
  9. gavywill
    Jun 2012
    101
    UK
    Fuser roll gets contaminated, Also sticks to the fuser roll. Causing the machine to stop.
  10. lopeza
    lopeza Senior Member
    May 2012
    56
    western ny, usa
    Only way to increase fuser oil is to change Metering blade with a different profile.
    gavywill likes this.
  11. peels
    peels tree killer :)
    Dec 2010
    1,113
    southeast iowa, usa
    Interesting....Ive had this happen.
    i attributed it to buildup on the heat roller, where a thermistor is. not RDS turned off. Ill check that if it happens again.
    edit, I also use a few problem papers... cheating their setting like calling them thicker... or coated sometimes works.
  12. Milo Wilson
    Dec 2007
    477
    Arkansas
    Check and clean the metering assy. Might need a new wick and metering blade.
  13. gavywill
    Jun 2012
    101
    UK
    On the free flow or Creo, do you try the print output order with Ascending? Because ever since I've done this it helps with the curl and also seems to run alot better for problem papers. Also prints before it's fully processed.
  14. Milo Wilson
    Dec 2007
    477
    Arkansas
    Usually cleaning the entrance and exit decurler blue rolls will help with curl. If you are still having a problem with curl, there is a procedure to change a value in nvm depending on curl up or down.
  15. shah
    shah Member
    Sep 2019
    6
    ru
    offtopic. Who knows what is happening with the fuser roll, has used up its resource ?!
