1. The Color Printing Forum Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post presses, equipment, or parts they either want or have for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
Maintop DTP & PS3 V5.3 with upgrade to V6.0 - Limited Quantity Sale
Discussion in 'Prepress Equipment for sale' started by ExoticDPS, Aug 5, 2020.
Tags:
  1. ExoticDPS
    ExoticDPS Member
    Feb 2012
    8
    United Arab Emirates
    With its up-to-date closed-loop color calibration engine, MainTop DTP&SIII V5.3 can precisely identify chromatic aberration and correctly reproduce color under any condition. User can obtain colorful image with any kind of printing equipment supported by MainTop DTP&SIII V5.3.
    With its optimized precise screen dot, MainTop DTP V5.3 can produce vivid image showing fine layer and smooth gradation. Every copy you got may have photograph quality.
    MainTop DTP V5.3 can direct input PS, EPS and PDF format files which are created by photograph software including PhotoShop, PageMaker, Coreldraw, Freehand, Illustrater, AutoCAD, Founder, etc and easily edit and print them out with files of JPG and TIF format together.
    Professional Plate Making
    [​IMG]
    With its professional vector plot capability, picture and character can be reshaped, filled, gradated and shadowed, and various kinds of complicated figures and fine arts can be created.
    A Multi-picture input function added into its recent version enables it to input several pictures at same time, adjust size and arrange format of picture according to paper size. It may help professional user to save plate making time and increase operational efficiency.
    Seperate block print output,the largest output format is 130m×130 m, documents generated is not limited by WINDOWS 2GB.
    Color Control
    Companied with MainTop powerful color calibration capability, it can control ink quantity of whole picture, as well as ink quantity of single color for calibrating unique color and overall picture gamma.
    Key RIP Technology
    It enables user to select operation modes of output equipment for saving consumption materials of printer.
    It provides many color schemes, supports more ink combinations and helps you to meet more service requirements.
    Its auto-compensation capability can implement calibration based on output error of the printing equipment in order to maintain accuracy of large format picture, especially pictures that need to be combined together.
    ICC Color Management
    [​IMG]
    Instead of calibrator, MainTop color management system uses closed-loop color calibration function to generate MCM color characteristic (ICC) file automatically. It calculates the combination of different sized ink drops and RIP screen dot format which ordinary ICC does not involve. This is the most important technique for ensuring the calibrating effectiveness.
    The system can calibrate color and ink quantity according to characteristics of the ink and medium, implement accurate color management, and produce esthetic and colorful image under any circumstance.
    Printing Management
    Multi-job management capability can accomplish several queued jobs in priority order and its high speed RIP segment processing ability may allow user to initiate a series of printing by touching one key.
    Output buffering ability enabled by RIP techniques overcomes data capacity restrict of WINDOWS and supports extra large format printing.
    Adobe Official Partner
    MainTop RIP V6.0 supports Adobe PDF Print Engine and Adobe CPSI, can complete the interpretation of the PDF format, and better support PDF files.
    [​IMG]
    New Dot Curve
    [​IMG]
    The new dot curve can adjust distribution ratios of the small ,medium and large dot, optimize the small and medium dot and light ink in range, consummate the ink drops, produce vivid image showing fine layer and smooth gradation. Every copy you got may have photograph quality.
    High-speed 8-core RIP computing
    Optimization of Windows 8-core printing technology includes the more printheads combinations, high-precision photo and large data, printing speed has promoted more than three times. MainTop RIP V6.0 supports preview printing jobs after RIP, and be easy to see the output dot with high magnification zoom.
    Standard ICC Input
    System can input standard ICC profiles, can be compatible with ICC data files generated by other color management system, improve the accuracy of color management to meet the requirements of international color.
    [​IMG][​IMG]
    Six Color Channel Curves
    User can customize to modify large, medium and small dot and light ink output proportional, effectively solution output problem by the ratio of the dark and light ink.
    [​IMG]
    Support Barbieri and i1,Color Munki Photo Spectro Photo Meter
    MIMAKI / ROLAND / EPSON / MUTOH / CANON / HP / RODIN / HIJET / XENONS / YINTIAN / NTJET / SINO STORM / ZTPRINTER / TITANJET / TWINJET COMPATIBLE
    For Inquiries & Order : contact@exoticdps.com
  2. ExoticDPS
    ExoticDPS Member
    Feb 2012
    8
    JUST 3 MORE UNITS AVAILABLE
