R900 stops with bracke.
Discussion in 'Man Roland Printing Presses' started by drukman, Jul 27, 2020.
  1. drukman
    drukman Senior Member
    Mar 2016
    279
    Bulgaria
    I have a problem with a R900 shipped from Mexico. When the stop button is pressed, the machine stops with the brake. I guess this is a different security policy in America and Europe. Does anyone know where the switch is?
    2,875
    Hi, normally the Stop Button is indicated by factories, and other REGULATORIES building Codes for industrial machine , like IEC, NEC.
    In the case for some countries like: America(USA) +Mexico+Central America+South America, and other countries is mandatory to install Stop Buton for security reason, the same in E.U .
    In the case of your machine man Roland R900 according with the schematic , please look the switch, that you are looking for.
    +AB Feeder
    +AB1 Feeder switch console +JA
    +AB2 Feeder switch cabinet
  3. drukman
    Mar 2016
    279
    Bulgaria
    Chok, the first Roland I installed in 1988.
    My question is specific and is for specialists. I don't need meaningless answers in red.
    Excuse my straightforwardness
  4. mendietta
    mendietta Senior Member
    Oct 2019
    112
    Slovenia
    Hmmm... i had the same problem with 500, but problem was in main drive....
    Machine was stoping on stop-secure same as it stop when you hit non-halt button....
  5. drukman
    Mar 2016
    279
    Bulgaria
    Share, please.
    Where was the machine imported from?
    Do you speak German, Russian? If yes, give tel.
  6. mendietta
    Oct 2019
    112
    Slovenia
    No, sorry, only english....
    Machine was from EU, instaled in Serbia. But it was running normaly for 4 years.
    Problem was in main drive board that compares speed of machine(baumuller AC drive).
    I dot have documentation here but it is serie 524, first one with AC motor. We were comparing drive with prodrive program and rtr with codeman... 900 use Siemens drive so i dont know how it compare speed... i instaled only 2 900 machines....
  7. drukman
    Mar 2016
    279
    Bulgaria
    The speed comparison is the same as on the R700. I will check the brake output. And n=0 in settings.
    Thanks for the idea.
  8. mendietta
    Oct 2019
    112
    Slovenia
    No prolem...
    Board that was broken is ENC-02 in bmaxx 4400...
  9. drukman
    Mar 2016
    279
    Bulgaria
    The AC of the 500 is different, but the idea of the main drive is good. 900 has 2 stop commands to drive. Fast and normal ....also the brake is controlled from there.
    Tomorrow I will look at the configuration.
    Thanks a lot!!
    I forgot to say. This 900 is 15 years old. The first generation. 90% the same as 700 before 2000.
    mendietta likes this.
