SM-74 Details
Discussion in 'Heidelberg Printing Presses' started by Thayanithi Kokulan, Dec 7, 2016.
  1. Thayanithi Kokulan
    Thayanithi Kokulan Member
    38
    Sri Lanka
    I am planning to buy SM-74 2 color printing machine. Can any one let me know what the things to be considered when purchasing SM-74. Can anyone explain what are the sections of the machine should be checked and what the prints should be taken.
  2. exheidmech
    exheidmech Senior Member
    May 2009
    674
    SM74 is not unlike any other machine. Check condition of all printing cylinders, indicating the cylinders would be best but doing breakaways would be ok as well. Another important thing I always do when inspection a used machine is always ask the customer to see the grease gun used for maintenance. This does a few things. First it will tell you how often the machine was greased. If the owner cant find or doesnt have a grease gun, you know it was never greased regularly. Also, will tell you what kind of grease was being used. Everything else is pretty normal stuff. Check rollers, belts, filters, central grease system (look for flow grease canisters to confirm correct grease is used). Since its not a perfector its pretty much straight forward.
  3. Thayanithi Kokulan
    38
    Sri Lanka
    Normally what are the manuals comes with SM-74 machine.
    1. Operator Manual
    2. Parts Manual
    3. Service Manual
    4. Installation Manual
    If any of the above manuals available is it possible to email the softcopy ttkokulan@gmail.com
  4. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    Only operator's manual and parts manual comes with press.
  5. Thayanithi Kokulan
    38
    Sri Lanka
    Yeah i accept but the problem is some machine re sellers do not provide them.
    Does anyone has SM-74 operator manual via Soft copy.
    Because i need to get some Idea about SM-74
  6. NimeshSilva
    NimeshSilva Senior Member
    Jan 2013
    246
    Sri Lanka
    Hi Mr. kokulan,
    What Mr. Asif said is 100% correct. And also I would like to add more to his answer. I suggest you to buy a SM74 with high pile delivery. (If you have enough space for the machine , obviously) Because the electronic control system is different what comes with the standard delivery machine, which is comparatively easy to diagnose and repair. And also check for any error codes in the display before you buy.
    Furthermore, if you're buying the machine from a local trading company, make sure to go for a reputed company, otherwise you will experience some warrenty problems. And you wish to import directly by yourself, I prefer you go there and check the machine personally with a technician / engineer to check the mechanical parts (cylinders especially) but please note that nobody can give a guarantee to the electronic control system. (It can fail in any instance.) And also the installation should be done by good and experienced technicians and/or engineers.
    Hope this helps
  7. Thayanithi Kokulan
    38
    Sri Lanka
    Thanks for your suggestion.
    Can anyone email me the maintenance manual and operator manual of SM-74 because i am planning to buy SM-74 so prior to that if i can get the manuals then it will be easy to understand about the machine.
  8. Thayanithi Kokulan
    38
    Sri Lanka
    The printing work most of them i do is 2 colours and for certain months only we get 4 colour jobs and i am not doing any quality jobs and currently i am having one KORD and KORS so if i am going towards a 2 colour machine i think SORMZ will be cost effective because for SM-74 Alcohol expenses and A/C cost and Maintainance cost will add i think what is the opinion about this
  9. aqazi81
    Oct 2009
    827
    KARACHI PAKISTAN
    As I quoted you in another post similar to this, SORMZ is a good machine, you cannot compare it with SM74 which has many advantages over it but It will get the Job done. Alcohol/IPA costs are not much if you calculate the amount of time and hassle needed it takes to clean and maintain the conventional dampening.
  10. Thayanithi Kokulan
    38
    Sri Lanka
    Hi,
    Can you let me know is there any method to calculate Alcohol/IPA Consumption.
  11. Thayanithi Kokulan
    38
    Sri Lanka
    Also in the SX datasheet it says that IPA Consumption has been reduced in SX Series, So normally in SM series the IPA consumption is more? So i am buying used latest year models of SM-74-2 will the IPA consumption is less comparing with the older models
  12. turbotom1052
    turbotom1052 Senior Member
    1,051
    Vermont
    There is no reason that a properly setup Speedmaster should ever need to run more than 5 percent IPA. Most can be run on zero IPA if you're willing to work a bit at it.
  13. Andrei83
    Andrei83 Member
    May 2017
    60
    Russia
    How is this done?
  14. turbotom1052
    1,051
    Vermont
    Combination of ways. First requirement is commitment. Then you need to find a chemistry that works. This chemistry will include an alcohol substitute. You may need to experiment with a few different products in different formulas. You will need good rollers that are set correctly and a softer durometer water form and pan roller. You may even need to go with a pan roller that is ground parallel instead of crowned. The roller settings in the dampener need to be accurate and maintained, and set a little tighter than with IPA. Lots of guys give up on running IPA free at the first sign of problems. This is where the commitment comes in. Good luck if you choose to go this route, and know that there are many on this forum that are well versed in how to do it.
    Andrei83 likes this.
  15. Thayanithi Kokulan
    38
    Sri Lanka
    hi,
    Please check the attached image.
    Is it mandatory to have 12feet width to install SM-74-2 with the working environment, because I have a bit limited workspace.
    Also My press entrance is 6 feet do i need to extend the height to bring the SM-74-2 inside, i can extend the entrance maximum to 9 feet.
  16. kavinda bandara
    kavinda bandara New Member
    Jul 2018
    colombo
    Hi
    I'm from SL
    I have SM74-1 machine.
    Is it auto wash in this machine¿
  17. NimeshSilva
    Jan 2013
    246
    Sri Lanka
    Hi
    Auto wash what?
    Roll? Blanket? Impression cylinder?
    There should be. But may be they have removed when you buy it. Who knows...
    See whether the water tank is there under the side platform.
    Cheers.
  18. kavinda bandara
    Jul 2018
    colombo
    Roller wash. Blanket ash is disconnected. All are there.
    The problem is need to wash by button pressing.
    not programmed.
