GTO52 2 color Feeder problem
Discussion in 'Heidelberg Printing Presses' started by Abraham Go, Dec 17, 2019.
  1. Abraham Go
    Abraham Go New Member
    Dec 2019
    Doha, Qatar
    Hello, can anybody know how to adjust the Swing gripper at the feeder. trouble is Paper tearing at the swing gripper only.
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,035
    US, Midwest
    Likely the set screw in the eccentric adjustment for swing gripper opening cam (release to impression cylinder) has loosened. Much has to be assembled to work on it, but look for 17mm hex, and put spanner on it and lightly try to turn it. If it moves freely, the eccentric may have to be replaced. I may be misunderstanding you, are you saying you see it tears sheet visibly at the feedboard?
  3. alibryan
    alibryan Senior Member
    May 2014
    219
    Somewhere
    Is the swing gripper simply not opening in some places?
