CMS-3436 monitor replacement Polar 115
Discussion in 'Cutters and Trimmers' started by cc1433, Jul 7, 2015.
  1. cc1433
    cc1433 Member
    Nov 2010
    47
    Sri Lanka
    Hi,
    I would like to know if anyone has successfully been able to replace this monitor using a VGA monitor on their polar gullotine, Using an EGA-> VGA converter card?
    As currently my monitor is not working. So trying to look at what option I have.
    Thanks,
    Charith
  2. Coloured paper
    Coloured paper Senior Member
    Oct 2012
    258
    Germany
    Hi!
    If you connect an old television to the coaxial cable it will work. I saw a lot of machines with a normal television.
    I never heard about any working converter, adapter, etc.
    Best regards
    Coloured paper
  3. cc1433
    cc1433 Member
    Nov 2010
    47
    Sri Lanka
    HI,
    Coloured Paper, thanks for you reply. What I forgot to tell you is that my monitor was hooked up using a 9pin cable. And NimeshSilva stopped by and had a look at the setup and is helping me to resolve the issue. And he opened the cover at the bottom of the machine and showed me that there is a coaxial output, so if we are unable to resolve the issue with the monitor, he would look at your suggestion of hooking up a tv to the guillotine.
    Regards,
    Charith
  4. NimeshSilva
    NimeshSilva Senior Member
    Jan 2013
    246
    Sri Lanka
    The monitor is not the original monitor from polar. Somebody had replaced it with an old computer monitor with 9pin CGA/EGA connector before import it. However, there was an issue with the monitor power supply and I was able to repair it. Now the monitor is back to live and working well. :)
  5. Coloured paper
    Oct 2012
    258
    Germany
  6. NimeshSilva
    Jan 2013
    246
    Sri Lanka
    Dear CP
    thank you very much. :)
  7. cc1433
    cc1433 Member
    Nov 2010
    47
    Sri Lanka
    Hi,
    This problem has risen again, now trying to figure out how to use the BNC port. So what I tried was to connect one side to the BNC port and the other to a RCA port. But Sadly this didnt work. Please see the method I used. Im trying to hookup a LED TV to this.
    Tried doing a 9pin converter to 16 pin VGA that didnt work.
    Would really appreciate, some help.
    Thanks,
    Charith
  8. CHOCK
    2,874
    Please let me know exactly, what do you want to do ???
    In order to help you
  9. NimeshSilva
    Jan 2013
    246
    Sri Lanka
    Hi Charith
    I can do like this. Let me know If you're interested.
  10. CHOCK
    2,874
    Great Buddy
  11. Mattias
    Mattias Member
    Aug 2012
    9
    Sweden Stockholm
    Hi NimeshSilva
    I am interested in a solution like this to my Polar 137 MON.
    Are you using an ordinary PC-monitor and a signal converter for this?
    In that case can I buy it from you?
    Mattias
    Sweden
  12. rspblake
    rspblake Member
    Dec 2013
    27
    london
    This is what I fitted the other day, I have been able too use the original slide bracket as well..
    Rob
    GUILLOTINE SPECIALISTS
    Repro-Link, Seven Acres, Carshalton Road,
    Woodmansterne, Banstead, Surrey, SM7 3HR, UK
    Tel: 017 3737 1234 Fax: 017 3737 0101
    sales@repro-link.com www.repro-link.com
    'SERVING PRINTERS SINCE 1986'
  13. Alonex
    Alonex Senior Member
    Oct 2019
    122
    USSR
    Dear Sirs,
    May it be better, to adapt a smart phone and to configure the machines via Whatsapp as you like, until its battery becomes dead..
    We have adapted a "professional" NEC LCD 22" monitor to a machine about two years ago. A few months ago, this display became faulty w/o reason (it was even separated mechanically of the mechanical stresses of the machine), while being absolutely irreparable by the OEM's definition ("New" technologies, or "High-Tech", "LED",.. you know and like such features), and it was rejected with its slide bracket and with the mechanical LPF.
    In opposite, CRT monitors work since ~80's, are repaired and refurbished till now even in military applications. Once, our CRT monitor, improperly mounted by a machine owner, has fell down on the machine table. After a broken BNC connector replacing, the monitor was returned on its duty, although this is not a rule.
    Again, we suggest to repair your old-, or purchase new/used CRT monitors for this and for other industrial applications, when possible.
    We still have new CRT color and monochrome monitors (old stock) which are custom modified for specific applications. We, and other Labs still repair and re-manufacture CRT monitors, replacing even the CRT tubes. In addition, trade-in offers will save you a few money for a spare smartphone battery.
    http://www.alonex.co.il/pdf/AX-PLR.pdf
    The industrial and far Cosmos will not be conquered with a "green" wind power nor with a "blue" smartphone , but with the "dirty" nuclear power and with the smart people.
    Regards,
    Oleg T.
