Help! laser not working and no errors on screen.
Discussion in 'DI Presses' started by vanceibz, Sep 1, 2017.
  1. SatLangama
    SatLangama Member
    Oct 2018
    14
    yaoundé, Cameroon
    Ok i see. So what is the normal position of that metal? Because i so it and it is pushed in and not out like in the picture. Tomorrow i will snape a pic and show you. Thanks for this step.
    2,871
    1) The scanner is coming with Presses with the PDS-E)
    2) Do the maintenance Screen , for better troubleshooting
    3) Interchange the Laser unit who is working in the unit , that is NOT working.
    4) If both unit is NOT working see schematic diagrams, and test the Voltages.
  3. SatLangama
    SatLangama Member
    Oct 2018
    14
    yaoundé, Cameroon
    Dir Sir
    Hi tried pulling out and in that small metal, restarted the machine, but nothing changes.
    Whatch the attached video so you can see what i get. Once the computer finished booting up, the screen stays at ATTENDRE (WAITING in english)
  4. SatLangama
    SatLangama Member
    Oct 2018
    14
    yaoundé, Cameroon
    Hello guys. When i closed the dialogue ATTENDRE displayed on the scree, i could read the following error:
    Run-Time error 91
    Objet variable or With block variable not set
    See picture. How can i solve this
  5. CHOCK
    2,871
    Dear Sir:
    1) Do the maintenance Screen , for better troubleshooting go the Menu and follow steps
    2) Interchange the Laser unit who is working in the unit , that is NOT working.
    3) If both unit is NOT working see schematic diagrams, and test the Voltages.
    4) iF The steps 2+3 Is not Working - Do the configuration Laser Unit;
    There are 2 laser units with 24 laser diodes in each laser unit on this press. The configuration is 6 modules with 4 diodes
    in each module. One laser unit images the plates for 2 units of the press.
    On the operation stand screen, click [DI Mainte] (1) -[Laser Set] (2) to
    open the [laser set] screen. Adjust the laser power.
    I do not see that you follow this, in short you said Laser is NOT working, please do the steps 2+3
  6. SatLangama
    SatLangama Member
    Oct 2018
    14
    yaoundé, Cameroon
    Dear Chock
    Thanks for your replies. As i said, once the computer finishes to boot, it goes straight on ATTENDRE (WAITING) screen as you see on the picture and after that nothing happens and i can’t do anything. I cannot even navigate on the panel, i can’ select DI maintenance. Its just stuck there.
    See very well the picture attached. Also look very well all pictures i sent before.
    Thanks again
  7. CHOCK
    2,871
  8. SatLangama
    SatLangama Member
    Oct 2018
    14
    yaoundé, Cameroon
    There will not be any problems with OS Windos xp installed? I don'thave any recovery CD and don't have xp windows to recover data. Do you conform that i will not loose anything?
  9. CHOCK
    2,871
  10. SatLangama
    SatLangama Member
    Oct 2018
    14
    yaoundé, Cameroon
    Hello.
    We finaly solved the problem. The thing is that some files that where to sent to the press were not well renamed. When you send a file to the RYOBI operation stand, we don't have to put any caracters on it. That is what our pre-press colleaugues did as mistake and then the application on the stand were bugging. We delated all the job on the RYOBI stand, restarted the machine and everything came to normal.
  11. CHOCK
    2,871
    Great Buddy!!
  12. vanceibz
    vanceibz Senior Member
    Apr 2015
    135
    spain
    Yes thats correct.. we had the same problem. Forgot to mention this..
  13. CHOCK
    2,871
    Great !
