Schneider Senator 76 SC
Discussion in 'Cutters and Trimmers' started by Ray123, Jul 4, 2018.
  1. Ray123
    Ray123 New Member
    Jul 2018
    Lancashire
    The machine has been moved to our new location but now on start up the back gauge has reset and is way out of calibration. Does anyone know how to reset calibration?
    The screen is showing 3333.33 on desired location but 0 on actual. When I enter a desired measurement the back gauge moves to a random measurement after pressing enter.
    I am sure I remember this happening once and we needed to input a code to set calibration but this way a while back and we have since lost the code and don't know how to enter it either way.
    Many thanks
    Dale
  2. Alimaatouk
    Alimaatouk Member
    Oct 2015
    6
    Lebanon
    I have the same problem can any one help me please
  3. CHOCK
    2,875
    Hi
    Please
    1) see if are all connector very well.
    2) look for loose and break wires.
    3) look if code 56 is good.
  4. adnan azzam
    adnan azzam Member
    Jun 2018
    19
    Damascus
    Dear Ray
    I think you have to put the backguege behind the refranc point and run the backguage foward until the refrance point
    regards
    Adnan
  5. Alimaatouk
    Alimaatouk Member
    Oct 2015
    6
    Lebanon
    good day sir
    What’s code 56 and how to set it
    My problem is that i have 2 mm difference between the display and the real cut
  6. CHOCK
    2,875
    look for Edge connector board contamined, Clean it.
    Most of the electronic board problem, is there!!
  7. Alimaatouk
    Alimaatouk Member
    Oct 2015
    6
    Lebanon
    Thank you for your reply but the problem is in the reference point i need the code of reference point correction because it displays 555.55 but in fact the cut is 2 mm less
    Best regards
  8. CHOCK
    2,875
  9. Alimaatouk
    Alimaatouk Member
    Oct 2015
    6
    Lebanon
    Hello
    I press ?56? Then it must display 555.55
    Can I change it to 553.55
  10. CHOCK
    2,875
    yes you can sir.
    But follow the instruction in his operator manual.
  11. Alimaatouk
    Alimaatouk Member
    Oct 2015
    6
    Lebanon
    Ok thanks i will try and tell you what happens
  12. CHOCK
    2,875
    OK Sir
    let me know
