SM52 4+L insufisance of compressed air
Discussion in '4-Color Offset Presses +' started by katelay2018, Feb 3, 2018.
  1. katelay2018
    katelay2018 Member
    Feb 2018
    7
    Kinshasa DRC
    We have a machine Heidelberg SM52 4 + L of the year 2000. during the production the machine stops and grinds an error message: insufficiency of compressed air. But we find that the pressure gauge indicates that the pressure is good. We changed the air pressure sensor, we still have the same situation.
    Could you help me to solve this problem. because there are several stops of 10 or 15 minutes before the message disappears itself.
    2,877
    Hi sir
    Hope you are well.
    Try to bleeding the system first, if the problem does NOT resolve, look for
    Leaking system, use soap for to detect the leaking. is very useful and secure.
    Tight all terminal very well, and see if the fiting are damaged.
    Look for any valve is leaking and defective, uses some O-ring and fitting would be worn and replace it.
    Of course look for the compressor ,if the hoses are o.k and terminals. Tight and replaces if necessary.
    If you change the sensor, look if the voltage is properly in the sensor or is faulty too. Repair.
    DIDNZU likes this.
  3. katelay2018
    katelay2018 Member
    Feb 2018
    7
    Kinshasa DRC
    Hello sir
    We followed all the directions.
    We have eliminated air leaks at distributors. We checked the connections of the pressure sensor control circuit by correctly displaying the plugs.
    We now find that the compressor stops when the maximum pressure is reached.
    Tomorrow Monday we will make the impressions and I hope that the machine will work well.
    We thank you
    And you will keep abreast of the evolution.
    Thank you very much
  4. CHOCK
    2,877
    Hi
    I appreciate a Lot of his words.
    Strong recommend you, to make maintenance the compressor Motor.
    Normally any electrical motor, will be take in maintenance every 12 months: cleaning, Lube, ball bearing, inspection, etc.
    The lack of maintenance, provide many inconvenience with the Time.
    In my over 46 years of Senior BSEE +P.E experienced in Troubleshooting, installation, Advice, maintenance, etc As electrical +electronic engineer, 95% OF the customers they Do not take
    in consideration the recommendations by the factories in doing, the maintenance works for many devices.
    DIDNZU likes this.
  5. Abhi
    Abhi Member
    Mar 2017
    80
    Nepal
    And do drain your compressor regularly.
    Else it will be just water and no air.
  6. CHOCK
    2,877
    Yes is a Good point ; to drain air, and Water to due the condensation in the same
  7. Abhi
    Abhi Member
    Mar 2017
    80
    Nepal
    Thanks Chock.
  8. katelay2018
    katelay2018 Member
    Feb 2018
    7
    Kinshasa DRC
    So far everything works after the intervention made on the basis of guidance;
    Thank you a lot.
    Abhi likes this.
  9. Abhi
    Abhi Member
    Mar 2017
    80
    Nepal
    Good to know. Cheers.
  10. CHOCK
    2,877
    Great buddy
  11. turbotom1052
    turbotom1052 Senior Member
    1,054
    Vermont
    If you currently have house air then I would suggest you plumb in some copper lines to supply "house air" to the small press side compressor. It would be STRONGLY advised that this "house air" is plumbed through an air drying system. Failure to use dry air will result in a premature failure of the poly lines and fittings if it hasn't already occurred.
  12. Diagramamen
    Diagramamen Member
    Apr 2016
    25
    Brazil
    I recommend that you check this relay (15Y11) there may be intermittent failure.
  13. CHOCK
    2,877
    Let me know
    if you fix it?
  14. Diagramamen
    Diagramamen Member
    Apr 2016
    25
    Brazil
    I posted pictures in my previous answers to help but they do not appear now.
    Removed by moderator ???
    What is the reason ??
  15. Color Printing Forum Admin
    Color Printing Forum Admin Administrator
    Jul 2006
    315
    Sorry for the inconvenience and thanks very much for taking your time to help others. It appeared the schematic could violate Heidelberg's copyright or was from a Heidelberg service document, so it was removed due to copyright concern.
  16. Diagramamen
    Diagramamen Member
    Apr 2016
    25
    Brazil
    It's ok. I get it. I'm sorry for what happened.
