Midlan Infrared Dryer systems
Discussion in '4-Color Offset Presses +' started by Griznarf, Feb 5, 2018.
  1. Griznarf
    Griznarf Senior Member
    Jan 2010
    81
    Ontario, Canada
    Does anyone have any information on Midlan IR dryers? I have a press with one on it and need the operator, parts, wiring and service manuals for it. It is going on another press.
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,036
    US, Midwest
    Hey Griz, I installed these for Midlan in my area until they went out of business, there was really no documentation sent, except for one page of basic install info. The only info I can give you is that you can get lamps from Soneko.
  3. Griznarf
    Jan 2010
    81
    Ontario, Canada
    Thank you Junker. I kind of figured that. It won't be the first time I've had to make a wiring diagram to re-install it on another press.
  4. Saravanakumar
    Saravanakumar New Member
    Oct 2018
    Indiw
    Dear Sir,
    Recently I installed Ryobi 3304HA machine, equipped with Midlan ir drying system. But I don't have the wiring diagram for Midlan. Please help me to install this equipment.
  5. Saravanakumar
    Oct 2018
    Indiw
  6. junker1984
    Jan 2010
    1,036
    US, Midwest
    See second post in this string. The only documents shipped with these dryers while the manufacturer was in business was an installation diagram specific to the press it was ordered for.
  7. junker1984
    Jan 2010
    1,036
    US, Midwest
    If you’re going to install it on the same model press, it will have all necessary brackets. If the press is different, you’ll have to likely modify or make new brackets.
  8. Luis mendez
    Luis mendez New Member
    Jan 2023
    República Dominicana
    Hi, I brought a piece of equipment and it came with the one connected in this way where a signal for the dust is connected, and the horn to make the sound before turning on
  9. CHOCK
    2,877
    I saw it the green or Ground, is NOT connected properly , connect to the chassis, and see if every ground is connected properly for the Dust device, and blue wire is NOT connected!?
    Connect it , according the schematic wiring diagrams, Do you have ?
  10. Luis mendez
    Jan 2023
    The blue wire is the signal from the horn, I put it like this just to show it, and it wasn't all connected yet, I just showed it so you can see it
  11. Luis mendez
    Jan 2023
    I'm not looking for help, I'm just showing that this is connected like this and it's working fine, the machine's manual doesn't contradict it, it just says that it's a signal for the dust.
    I show it in case it helps someone, I have been installing the Ryobi 3304h for years but I have only seen the Tempest and midlan systems
  12. CHOCK
    2,877
    Ok sir.
