DIY Fiery RIP
Discussion in 'Fiery RIPs' started by MstrXplodR, Nov 16, 2017.
Tags:
  1. MstrXplodR
    MstrXplodR New Member
    Nov 2017
    Los Angeles
    Good morning Gents, Has anyone in this forum tried building their own RIP? Basically, it's just a PC that is meant to handle image processing, right?
  2. Pr0cess0r
    Pr0cess0r Member
    Apr 2019
    6
    Blainville Canada
    I'm curious about this. I think you also need the interface card and where you take the software?
  3. Biggs
    Biggs Senior Member
    Mar 2017
    216
    Edison, NJ
    Interesting idea, I'll give you that. I imagine you could achieve a basic RIP of sorts, but to create a user interface like Command Workstation, or incorporate features that directly feed into the digital press would be a huge challenge. Take for example changing toner dither/dot pattern, image shifting or enhancements, Calibration - Come to think of it, a solid 90% of all EFI's job properties would be difficult to replicate.
    Of course, if you don't care about the output, a basic RIP would save you a considerable chunk of change. Just simply use the stand alone print driver.
  4. DigitalColorGraphics
    DigitalColorGraphics Member
    Mar 2009
    16
    So Cal
    Are you talking about RIP software or the actual computer? Way back when my delta rip for my Heidelberg died and I took it to my local PC repair shop...he built a new computer and moved the card and whatever else he needed over to the new one and it worked great. That system used a dongle.
  5. PressingPrints
    PressingPrints Member
    Jan 2022
    12
    Florida, USA
    Why can’t one get a simple PC and install the EFI command station software? I don’t understand why you must have a stand-alone PC just to run EFI.
