DI haults while burning plates
Discussion in 'DI Presses' started by The Ticket Dr., May 17, 2017.
  1. The Ticket Dr.
    The Ticket Dr. New Member
    Oct 2016
    the ticket dr. fenton mi. USA.
    while burning plates press stops imaging and gives a code 12-06 is it a chain issue. Thanks Darryl
  2. mrheidelberg
    mrheidelberg Senior Member
    Jan 2008
    761
    United Kingdom
    Possibly....delivery grippers may be touching & tripping the paper overshoot trip at high speed.
  3. Paul Cavanaugh
    Paul Cavanaugh Senior Member
    Dec 2009
    630
    Kennesaw, GA
  4. The Ticket Dr.
    Oct 2016
    Thank you for the tip! chains seem to be worn. How much should I tighten, and is there a process to adjusting them.
  5. Paul Cavanaugh
    Dec 2009
    630
    Kennesaw, GA
    Technically the tensioners are self-adjusting, although, using a pin wrench, you can open the gap the spring is in to apply more tension to the chains. The spring gap is set at the factory to 31mm. If it is over 35mm you will need new chains.
