IR Dryer lamps not switching on. Error: A30 current line unknown
Discussion in 'Heidelberg Printing Presses' started by davianafg, Apr 7, 2017.
  1. davianafg
    davianafg New Member
    Apr 2017
    4
    Malta
    Hello All,
    We have a problem with an IR Dryer not switching on properly. On power up, the front panel ComCon110 unit boots up normally, cooling blowers will come on but an error is displayed accompanied with a red blinking LED. The error is:
    A30: Current line unknown.
    The unit does not allow you to continue operate as the error apparently has to be cleared first which we can’t find how.
    Checked on its user manual and A30 is apparently related to the lamps but does not mention the error we are getting. Checked the lamps, the power supply and contactors but all seem OK. Machine still down.
    In view of the above has anyone encountered such an error please and how to rectify it? - Or may be someone can send me the schematics of this unit?
    Dryer type: Piller IR-Trockner SM74
    Thanks in advance for your help.
    2,874
    Hi, sir
    Good morning
    I see that you have Piller IR Dryer.
    Not mention if your Dryer is Normal or Extended Delivery and Frecuency 50-60HZS or for Ink or Coating dRYER Model
    Your problem mentioned is ErrorA30 : that means: 1) The electronic pulse for AEG Thyristor regulator is NOT issued: Test the Thyristor with a Good
    DMM or Devices for Electronic Components, for a competent Electronic Tech or Eng, for Test. see your Schematic Diagrams
    2) Test However the +24Vdc in your power supply the Tolerance is very Close like: +-2% WITH a Good DMM like FLUKE or Similar
    3) Please Re-test your Cooling system Device(Hoses, Pump, or Compresor, clamps any device relationed with the system.
    4) Fans in Ceiling too, RETEST it. with a Good DMM.
    Of course can be another Reason, but please test this FIRST.
  3. davianafg
    Apr 2017
    4
    Malta
    Hello Chock,
    Good morning.
    First of all thanks for your reply.
    The dryer is a normal one for Ink with a high pile delivery. The frequency is 50Hz. The error appears immediately as soon as it boots up as apparently performs some sort of self check before it lets the user to operate. So I think the thyristor would not become activated yet. The 24Vdc supply is correct. Compressors and cooling fans were individually tested and works fine.
    We would appreciate if we can have the electrical diagram/layout of this unit, because its not incorporated with that of the machine.
    Thanks for your support.
  4. wunmi-50
    wunmi-50 Senior Member
    Jan 2013
    90
    Lagos,Nigeria,Africa.
    Hi Davianafg,
    If you are still having this error A30, to solve the problem, you have to change the lithium battery in the PLC(ComCom) to type CR2450 by either Eveready, Toshiba, etc. The lifespan of these batteries is about a year, so on installation it would be recommended to instal a new battery.
    Pls do this and let's know the result. Good luck.
  5. davianafg
    Apr 2017
    4
    Malta
    Hello Wunmi-50,
    Last time I checked the battery, it had correct voltage.
    Unfortunately this week I'll be away from this machine and won't be able to continue checking it for the moment. I will continue and post again next week.
    Thanks for your help.
  6. davianafg
    Apr 2017
    4
    Malta
    Hello All,
    Following all checks I decided to reteach the characteristic - although the error is not mentioned in the service manual! Then the lamps came on and the error cleared. IR unit worked OK then.
    Thank you all again guys for your help.
  7. CHOCK
    2,874
    Great Sir
    Good job.
  8. Charly7
    Charly7 New Member
    Oct 2017
    4
    England
    Thanks you for help before.
    Do you have IR dryer Piller concom electric diagram for sm74?
    Maybe all manual in english?
    There is the same problem as guys speaking about - A30!
    Can you please send me diagram?
    Great thanks you before!
  9. CHOCK
    2,874
    Dear Sir:
    Hi hope you are well in union with his family.
    The problem that you have is with the Thyristor regulator AEG, No pulse arriving for excite the Gate of
    the same electronic Device.Can be there excessive plate Temperature.
    You must install some additional Fan, for to help reduce the temperature.
  10. Charly7
    Charly7 New Member
    Oct 2017
    4
    England
    Dear Sir!
    Are You receive my email?
  11. Sandeep kumar
    Sandeep kumar Senior Member
    Jan 2018
    122
    Gurgaon
    Hello Davianafg,
    Can u guide me how to reteach the charecteristic
  12. ashok kumar
    ashok kumar Senior Member
    Nov 2017
    224
    india
    It is written in piler IR Dryer manual how to create the Characteristic curves.
  13. Tank
    Tank New Member
    May 2020
    Bowling Green,KY
    We have an A30 code and have tried the items suggested,but no luck. I have an electrician that says he would need a diagram to fix it, it's a Piller 1998 serial # 86736 400v/3. Any info would be appreciated!
  14. CHOCK
    2,874
    Normally for this king of equipment: problem is : Pulse for the AEG Thyristor regulator is NOT issued. , (Excessive guide plate temperature)
  15. CHOCK
    2,874
    You need, electronic Tech or Engineer, they have more skill and knowledge for this kind of equipments.
    They can use the Oscilloscope, in order to test the pulse for Thyristor.
    Electrical is Not dominion for this kind of tech electronics Devices.
    Let me know please
  16. Mathew
    Mathew Senior Member
    Apr 2010
    533
    Kolding-Denmark
    Was the dryer in production? Did you have power cut off or failure recently? i don't have the manual in PDF but if you have Dryer instruction manual, you have to find the procedure for Power Line Synchronization. You need to log with password into service on ComCon and then follow the instructions. It takes few minutes and you can see lamps turn ON, OFF and dimming and OFF again. Then the unit is ready to run.
  17. CHOCK
    2,874
    Hi : did you procedure for A30+
    as I did indicate you for this kind of equipment?
  18. ashok kumar
    Nov 2017
    224
    india
    Hello
    in the PLC there is a program store"charharstic curves" which has been lost in your case .You have to create new curves .
    once the curve has been recorded then errro will go
    I had done this so many time
    if need any further information pls mail me contatc me
    AShoK kumar
    GSA GRaphic and Print Solution
    Sevrcie provider for Heidelberg Equipments in india
    ashok10eja@gmail.com
    what app +91 9818492864
  19. CHOCK
    2,874
    Waiting any news
  20. Chtara Moez
    Chtara Moez New Member
    Apr 2023
    Tunisia
    Hi
    Can you please give or show us how to create the characteristic curves for the piller IR dryer, I have A30 and A50 problem and I don't have the manual.
