Hi everybody i have water based laminator , when i finish the job i feel difficult to clean up the glue from the roll,while the glue be dry i rub it hardly with alcohol , but it take a long time , and make my arm so stiff can anyone tell me how the right to clean up the glue roll? thank you
Remove film, and turn the laminator on. Allow it to warm for 15 minutes to soften the adhesive. Turn the laminator off. Rub the rolls with a stiff rubber eraser to roll the adhesive into small balls. Wipe the roller with a damp cloth to remove the balls of adhesive. Hope this helps! -Curtis
Thank you for your advice, i Have tried it,but is still same difficult to remove the dry glue from roll maybe you have any idea? thank you
Hi , you use the water base varnish, you need to use the water to clean the roll instead use the alcohol, the alcohol is use to clean the UV varnish. please try, wish this can help you.
