Movement of first 2 units
Discussion in '4-Color Offset Presses +' started by eltitcho, May 21, 2015.
Tags:
  1. eltitcho
    eltitcho Member
    Apr 2012
    9
    Hereford
    Hi. we have a 4 colour b3 press and it runs ok but when we use all 4 units the image of the first 2 units is moving (like a double image). we've set all the grippers and they are fine but we cant seem to find out the problem. the units have a double impression cylinder (1 for units 1 and 2 and another for units 3 and 4) if that helps????
  2. headwebrat
    headwebrat Member
    Sep 2014
    26
    dallas,texas
    is this press a ryobi 3304?
  3. eltitcho
    eltitcho Member
    Apr 2012
    9
    Hereford
    no its a sanxin yk524 similar to a gronhi
  4. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    I don't know about the press that you mentioned but it is normally caused by worn grippers or cam follower, Gripper timings should also be correct.
    Check the cam followers and cams.
  5. Taymour
    Taymour Member
    Dec 2014
    6
    karachi
    Image Doubling
    It cant be traced without knowing the condition of doubling and where it is appearing. As sir A.Kazi said grippers can be the major reason behind it but if u have already done that then check your blanket backings. are they all of correct thickness and condition and it can also be caused by too wavy substrate.
    Rgds
    Taymour
  6. daniel77
    daniel77 Member
    Mar 2015
    27
    MAURITIUS
    Could you tell me if the doubling is on all sheets or it's one sheet ok and then the other not good...
  7. eltitcho
    eltitcho Member
    Apr 2012
    9
    Hereford
    the doubling is every other sheet. there is a double image on the left of a good image then the next sheet its the right of a good image
  8. eltitcho
    eltitcho Member
    Apr 2012
    9
    Hereford
    how do you check the cam followers?
  9. aqazi81
    Oct 2009
    827
    KARACHI PAKISTAN
    check them for excessive play or hair cracks.
  10. daniel77
    daniel77 Member
    Mar 2015
    27
    MAURITIUS
    Hi Eltitcho,here some guides which I hope will help you because many factors can cause Doubling in press.
    As everyone said try to check - the grippers/cam follower
    Improper transfer image blanket/plate - over/under packing-adjust correctly or try to change another blanket (brand) if you can
    Is it with thin/thick paper?unstability - run with minimum water
    Pressure problems in press -try to verify if pressure is stable between cylinders both sides
    Is your press old? -possibility of worn bearings or gears/try to find expertised solutions
    Good luck.
