Recent Activity
Activity stream for all registered members at Color Printing Forum.
Adil replied to the thread SM52 Perfecting changeover error, Monitoring of reversing drum - storage drum synchronization.
Please you told me that you have only p21 error code but if you have also p02 you have to check if clamping mechanism do not close (...
May 19, 2024 at 8:12 PM -
The meaning of p21 error code can be mechanical also boot problem . Compare the entires on the vatiant code with the supplied printout...
May 19, 2024 at 8:00 PM -
junker1984 replied to the thread DDS dampening GTO 52.
The DDS system utilized a number of parts used in the conventional system, though roller configuration was changed significantly. I was...
May 19, 2024 at 7:25 PM -
Sunilvaryani replied to the thread DDS dampening GTO 52.
Ok sir What about the dds dampening system Thanks Sunil
May 19, 2024 at 4:56 PM -
Kompac is a great alternative to the old conventional dampening systems on GTO presses, chemistry requirements are similar to that used...
May 19, 2024 at 4:54 PM -
Ahmed Mahrous replied to the thread Speedmaster 102-- 8 units.
Thank you mr/ashok kumar for your reply but all other motors like diagonal or margin working correctly from cptronic.
May 19, 2024 at 3:49 PM -
Cdel posted a new thread.
pan roller setting
Hi everyone, looking for some assistance. When setting pan roller. I go to where the water bead disappears and the 1/2 turn tighter on...
Forum: Heidelberg Printing Presses
May 19, 2024 at 3:43 PM -
ashok kumar replied to the thread Speedmaster 102-- 8 units.
After seeing on pic all seems ok It may be due any one of the switch on cptronic consle is faulty and remain presse(stuck) because if...
May 19, 2024 at 12:33 PM -
Hello Sir Is a kompac varn damper system ok for a gto press I’m consider to buy one Do it also use alcohol and what are the chemicals...
May 19, 2024 at 8:51 AM -
Ahmed Mahrous posted a new thread.
hello everybody i have a problem with adjustment of printing pressure. the motors are not flashing on cptronic but i can't increase or...
May 19, 2024 at 4:39 AM -
Sunilvaryani replied to the thread SM52 Perfecting changeover error, Monitoring of reversing drum - storage drum synchronization.
Dear sir I think my press pm 52 is having the same problem I got error p 21 The machine don’t move , manually it’s on straight...
May 18, 2024 at 8:01 PM -
digiMart has a new avatar.
May 18, 2024 at 7:14 PM -
Tihomir Vidic posted a new thread.
Duplo DBM 500 - stitcher unit does not return to the home position
Hello, does anyone have experince with error E72 on Duplo DBM-500 machine!? As you can see on photo, our machine makes 2-3 pieces...
Forum: Collator-Booklet Maker Systems
May 18, 2024 at 4:17 PM
